as mentioned.... found in southcoast22. 3 telescoping tubes, capped internally for floation? or to act as stops when sliding together? bracket on one
nothing ... each piece is about 1.25"-1.5" in diameter 36" long or ao.Sounds like a boat hook. What's on the ends?
capped internally about 4" in. either for flotation or to keep it from sliding together farther. no holes drilled in it, just a sliding bracket with a bolt to tighten down to keep the bracket in place.So both ends are sealed?
If it is, then why would anyone want a picture of itan invisible boat-thingy.
Sorry for the previous smart a$$ed reply. Is the picture in a JPG format ? Is it a reasonable size of a meg or two ?it won't go through
Sorry, can't help you with the app. I'm doing this from my wind up computer.I am doing this via the app
Whisker pole?
If it is, then why would anyone want a picture of it?
You'd get along great with a friend of mine who signs his emails "sent from my Olivetti portable."Sorry, can't help you with the app. I'm doing this from my wind up computer.
Picture looks too substantial to be a whisker pole. Maybe it could be a homemade gin pole for mast raising I guess.Whisker pole?
