I have to replace the vinyl bracket device that protects the halyards as they exit the mast. not sure what it is called. exit plate? exit sheave? the hole is about 3.5"x5/8" and has a screw hole drilled about 1/2" above the larger hole. any idea what this is called and where i can get replacements. i presume it is a standard equipment mast on a '91 Hunter 27. thanks for your help. Alan
