What is Inside the Arch
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
I tried to run a pair of wires inside the arch tube on my 2000 410 and there is something blocking the corners in the arch. I installed a cockpit light under the arch and wanted to run the wires inside the arch then in the side of the boat. When I got to the corner going from horizontal to vertical nothing would go through. Does anyone know what is inside the arch tube?
Jun 1, 2009
1,837
Hunter 49 toronto
Yes, I know the issue.
Where the arch screws onto the deck supports, the connecting pieces are actually solid cast stainless. They are welded onto the tube.
On my 49 there is an overhead pod with a stereo & light. Accordingly, Hunter drilled a hole through the casting. But, it was small, and I couldn't fish any additional wiring through it.
If there is nothing electrical already on your arch, then chances are you wont be able to get wiring through it.
May 7, 2012
1,545
Hunter e33 Maple Bay, BC
You may want to touch base with your dealer's service manager and/or Hunter support. I was about ready to give up but I conversed with both and I was literally given some inside (the arch tube) information that resulted in success. I was able to fish two 10 gauge wires down the inside of an arch tube, through predrilled holes in the casting and a predrilled hole in the base which allowed the wires to exit inside the boat. Total time for me to run these wires less than 10' was about 20 hours.
Jun 4, 2004
1,087
Tried contacting Hunter but no response yet.
Jim D
Dec 10, 2007
139
Hunter 410 Maryland
I have a 410. Installed solar panels last year. The wires I installed went through the arch and to the nav station. there is a opening in the ss tubing under the light and speaker pod on the arch. The tube is clear all the way down to the ss attach plate on the stern of the hull. That is were there is only a small opening around a 3/4 inch in the middle of the plate. You need to access the area in the locker on the port side above the fuel tank. Find the bolt pattern and you will see the wire for the speakers and lights there. I ran a electrical tape/fish up the arch and grabbed the tape when I saw it in the middle of the arch at the speaker/light opening. Not easy to do by yourself but a few beers and it can be done. good luck
Jim
Jun 4, 2004
1,087
Jim
We must have a different set up. I do not have speakers or light preinstalled under the arch. I installed a light under the arch and trying to run wires inside the tubing. Drilling holes for the wires is not the issue. The issue is the arch tube has something in it in the corner. Nothing will go through there, electrical snake, etc.
Apex
Jun 19, 2013
1,212
C&C 30 Elk Rapids
trick I learned from an electrician: Tie a plastic bag to a tracer string. Stuff that in the hole, and vacuum on the other end. We used that method for fishing a new 200amp service, but you may be able to perform the same method varying the size of the plastic "wad" to fit the application.
Jun 1, 2009
1,837
Hunter 49 toronto
If there is no existing wiring in the arch, then it is possible that Hunter made no provisions for any. Have you tried fishing through the other tubes? You might get lucky. The wiring might be longer to run inside the boat, but it's better than zero.
Aug 3, 2010
150
Hunter 326 Charleston SC
I had a similar issue where one of the cross bars on the arch was welded in place off to one side blocking the tube. I had to install the solar panel wires externally.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Try different tubes making the turn and look at all the tubes where they are bolted one the hull and if one of them has the hole
If not try different tubes when trying the fish line,my 2001 290 I had to just drill hole at bottom
Nick
