Mast stepping
I have a crutch that I made from a 2x4 and had it set in the gudeons. Then the mast was set in the crutch and moved back till the step was in the tabernacle. Beware however that gravity will take over. I had a dock line loosely tied over the mast using the handrails as anchors, to keep the mast from going over backwards. Then pin one side of the tabernacle. Put another dockline on the forestay and run it through a fairlead back to you in the cockpit. (I was doing this myself, but I do recomend getting help).Close the main hatch, take a deep breath and walk the mast up, realizing that theres no turning back once you start. When the mast is up, tie off the line on the foresay to keep the mast from going backwards. Then go forward and pin the turnbuckle. Afterwards, go back and put in pin #2 on the tabernacle. Finially, adjust tension on the turnbukcle. Personally, if the yard is willing to do it for a small fee, let 'em.
