What is a good replacement prop for my O'DAY 31
G
George Noyes
I have a 1986 O'DAY 31 with a Universal 18 (14HP). the prop is out 0.5 inches an a friend said I should upgrade my 2-blade to a Three blade, or folding prop. Any thoughts on the best way to proceed would be appreciated. Thanks, George on "Silver Sea"
K
Kevin l. Woody
Need clarifacation
Hello Geroge, Thanks for your letter. I’m not totally sure what you mean by the “propeller is out 0.5”? Anytime you upgrade to a three blade from a two you will see an increase of apx. 30% efficiency. This increase will allow the vessel to maintain its speed when confronted with heavy winds or seas. The three blade is also quieter when in use. If you are speaking of an increase of 0.5 in pitch, most any propeller shop can perform this with adjustment at minimal cost. If you e-mail to me engine, reduction gear and current propeller, I can calculate the needed unit for you. kwoody@pyiinc.com Hope this helps, sincerely, Kevin L. Woody
