What Electronics are on your 1997-1998 Hunter 376
Barry Rogers
I purchased a 1998 Hunter 376 from a dealer auction in Florida. Unfortunately, I haven't been able to contact the owner and Hunter's factory build sheet doesn't list the electonics that were installed on this boat in 1998 by the factory. Since they were all missing on the pedestal (stolen) when I bought it, all I have left are the cut outs and the uncut (nice of them) wires with plugs in the pedestal. Can any 1997-1998 376 owners out there give me a listing of what brand, model of depth, speed, wind instruments were mounted on your 376 from that period. It would be appreciated. Thank you.
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
Mine Came With
Raytheon (now Raymarine) ST 50 Depth, Wind and Log meters 115mm square. Also Raytheon VHF radio set into the panel. I added Raytheon ST6000 Autopilot so there were 4 identical meters across top of panel. Mostly the instruments were Raytheon but the purchaser could select which. My boat was built in June 1996
Dec 2, 1999
15,184
transducers should work with the newer instruments
Barry: You ST50 transducers (assuming that is what was on your boat) should work with the ST60 & ST60+ instruments. Check with Raymarine.
Patrick
St 50 transducer
Re:Steve Dion's commebt about the ST50 transducer, note that it will NOT work with ST60 instruments, they are not interchangeable, as per Raymarine. I have a broken ST50 transducer and can only use ST 50 stuff with it.
