What does a Hydro Hoist 4000L weigh ?
53
Wavelength 24 Columbia, SC
I am buying a sailboat and the Hydro Hoist 4000L it has been kept on. I need to know how much the empty hoist weighs so that I can take an appropriate trailer or truck to fetch it. It's a model 4000L with a lift capacity of 4000 pounds. I could not get any useful information from the manufacturer's website or by phoning them. :confused: I found the installation manual but it doesn't list the empty weight either.
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
Weight wise, if it's aluminum, only going to be 600-800 lbs...
But it's large and awkward...so you will want a long, tandem axle utility trailer to "stabilize" it during travel..
Aug 28, 2012
53
The Hydro Hoist 4000L has plastic floats and steel structure. My current plan is to use a flat bed trailer that U-Haul rents as a car transporter. It's tandem axle and I'm sure it can handle much more load. Still would like to know what the hoist weighs though.
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
A standard car trailer should have no problem moving that weight and would ease loading it aboard. If you take the truck and trailer by a truck scale you can get the weight of the total rig. Re-weigh your rig with the 4000L aboard and you will have the weight of the 4000L.
Ray
Aug 28, 2012
53
Still need the weight number
The car hauler is the default if I do not know the weight of the hoist. I would like to take a lighter trailer.
Squidd
Sep 26, 2011
890
