What do you sleep on?
SailboatOwners.com
What kind of material do you put under you at night? Have you stayed with your original closed-cell foam cushion? Replaced it with a newer, firmer version of the same? Did you switch to an inner-spring mattress, or perhaps get one with your new boat? Have you experienced a night on a Latex mattress, which many sailors claim to be the best on board? Share your firm positions on bedding, then vote in the Quick Quiz at the bottom of the home page.
E
Ed Schenck
Original foam, plus.
We have added the one inch pads with holes, I think from Homeplace. Improves comfort and allows for air circulation under the mattress.
Tom M.
Original + also
We have the original foam plus we place a couple therm-a-rest sleeping pads underneath which makes a world of difference.
G
Geoff
Added extra for ventilation
We added 'Ventair 15' under the original cushions - has improved comfort and eradicated moisture/condensation problems
TOM MCNAMARA
SLEEPING
As a live aboard,I never had any problem with the foam mattress on my 38 ft trawler and assumed the same when we bought a new 450 in 99 that came with a 7" regular mattress in both cabins. At first we heated with electric hearers[Freeport was only 7 cts per kilowatt] however when I took a suit out of the locker the sleeve was all mildewed as everything else in all lockers.When we looked at the mattresses they were wet on the outside. The next was to put in a Webasco oil fired heating system [$11,000.00].Two zones are controled by thermostats, and two zones, 1 port and 1 starboard that run up and down all closets,under bunks and couches and floor that run when ever either of the thermostatically [whaw, thats a big sunday word]controlled zones are running. The heat is great and the condensation has almost been eliminated axcept for a few minor areas and lockers that are too packed to allow circulation. The one problem is that I always seach for a cold spot when I am in bed.My next boat and girlfriend I am going to put the heat on her side of the bed.Boy I really used some big words,I must have had ABCDEFGHIJ[cant spell alphabet]soup for lunch, with a dictionary desert.
Jul 1, 1998
3,062
Use Waffle Pad
Originally we had problems with moisture buildup between the mattress and the plywood underneath. After a nights sleep we’d brace the mattresses up so they could air out but this was really arduous, there had to be a better solution. Like the previous posters, we subsequently added a waffle pad (very inexpensive, around $10 or $15) underneath the original mattress and the moisture problem has for all practical purposes disappeared. Also, the mattress feels a little cushier. No need to prop up the mattress. I like what one person said about their solution for ventilation and that was to remove the plywood and install some cedar battens. This would eliminate the need for the waffle pad and provide superior ventilation. Our area runs approximately 70 percent humidity, more or less, so that’s a factor also. What works for us on the west coast might work as well on the east coast, but it should help.
Bob
Mattress
An inner spring mattress. Makes living aboard more comfortable. Regarding an earlier post about condensation, we keep a hatch cracked and never have a problem unless we shut the boat up hurricane-tight.
A
Alan H. Liebnick
Sleep?.....
...What a novel idea. With a 8,6 and 2 1/2 year sleeping aboard is trying. However once they do fall asleep my wife and I are so tired we can sleep on a "bed of nails"...
Paul Akers
New High Density Foam
Last year we purchased a new, high density foam mattress to replace an old foam mattress that I was beginning to bottom out on. The new mattress took a bit of getting used to, but now it's as comfortable as at home.
Dick McKee
The one imporvement we're making this spring
is a new innerspring mattress. At 6'3" 200# the factory 4" foam is killing my back if we stay on board over a couple of nights at a time.
Bob Knott
Handcraft Mattress
I had Handcraft mattress make a custom queen sized mattress for our H380, with a special fold so we can use the storage areas underneath without disturbing the bed. Expensive but well worth it in my opinion. Bob Knott H380
Mark Johnson
OEM mattress is fine..
althought it's not as comfortable as the "pillowtop" mattress I have at home. The OEM inner spring mattress that came with our 460 works just fine!
L
Larry
Original pad and add a waffle
We use the original mat and added a waffle pad.
Bill Robb
O'DAY OEM is great!
The builders must have been looking out for us - the cushions on an O'DAY are the thickest in the industry! I've never had less than a perfect nights' sleep on board and I'm sure the thick cushions have a lot to do with it!
Michael Bell
Therm_A-Rest
Our H26 foam cushion was showing signs of collapsing under certain portions of my body. I didn’t want to consume to much height in a thicker mattress and loose head room. Could of gone to a higher density foam – but didn’t want the work to re-cover. So… I purchased two “Therm-A-Rest” self-inflating 1” pads. I’ve slept on these in the past camping, and they are unbelievably comfortable. I just put those under the existing foam pads – and it works great.
John
I sleep on
We found it desirable to replace the mattress on our 1987 Hunter Legend 37 with a new 5" foam one. It is very comfortable. Who wants to sleep on a matress that is 13 years old whose prior owner had a dog? It does put our face in the floor of the cockpit, but, hay, we dopnn't think of the clostrofobia.
Dana Roberts
In response to bedding quiz.
I live part time on the El Delphin, she gets scold and the those those 3" Foam cushions are not that comfortable. But QVC came to the rescue. Northern Nights feather bed and down comfeter, super warm and the feather bed gives an amazing amount of extra cush. It was the best $150.00 ever spent.
I
Ike Cook
I oughta try it...
I oughta try sleeping one of these times. I'm sure it would make those lousey 5 days in the middle of the week more productive.
SailboatOwners.com
Final results
Final results for the Quick Quiz ending 1/29/01: What kind of mattress do you sleep on? 62% Original foam 23% New foam 10% Inner spring 05% Latex rubber
Barrie McDonald
Reverse your Sleep Position
John, I also have a Hunter Legend 37 ,1988. My wife and I find we have more headroom by sleeping with our heads towards the bow. The matress is only 6 inches narrower but now we have more leg room. Barrie
