Peel-Away Bottom Paint Removal
I have a 1983 O’Day 30 that I stripped down to the gelcoat two years ago. Not sure how many coats of paint were on the boat, as the original paint was Pettit Unepoxy, and all subsequent coats were one of the Pettit mult-season paints that slowly wear off the boat. I used almost 10 gallons of the Peel-Away product and it does a nice job of cleaning the paint right down to the gelcoart. The upper sections were easier to do than the horizontal sections of the bottom, that usually required two applications. After peeling and scraping the paint off, I washed it down with water and all of the blue residue came off, and the gelcoat looked like new. You must wear protection, as the product will burn your skin if you leave it in contact for an extended period of time (like around my shirt cuffs). You also have to be careful where you dispose of the removed paint and Peel-Away removal cloths. You end up with a real mess. At the same time I did my boat, two other sailboat owners elected to have the yard remove their paint by sand-blasting with walnut shells. After the job, they’re gelcoat was not as clean as mine and they had to do some sanding. Their cost to sand-blast was almost the same as mine, and they had a lot less work. If I were going to do it again, I would have the yard sand-blast.
