Princess
While there may be those who do not like alcohol stoves, I still think they serve a purpose. Our Catalina 27 has the original Princess brand two-burner which was a factory item. Our boat is an older one...1972 vintage. When we took possession of the boat the stove was dry and the leathers were also dry. After filling it and oiling the leathers she lit beautifully and has held a charge in the pressure tank for as long as 60 to 90 days. Yeah, alcohol has it's challenges (moisture, moisture and lots of moisture often times leaving you smelling like a wino when you leave the boat after using the stove) and it isn't as hot as some of the other fuels, but it is safe and it does tend to get the job done. We also use one of those little butane stoves which stores in a neat little plastic carry case and stows neatly. In addition, a barbeque mounted on the stern rail makes a fine addition. Dollar for dollar I still think the alcohol stove is one of your better bets.John EastinOlympia
