Steve C
See my post last week on "Depth Sounder advise needed". I called West Marine and they had a transducer for my Standard Horizon DS45. I drove 2 hours each way to get it and hooked it up before installing it in the hull. I hung it over the side and got the same results on my display - - . So it's either the display unit or (and this could be considered a stupid question
) the boat is on the hard right now, so when I say hung it over the side it was not in water. Does a depth sounder need to be in water to echo back the depth? I tried a pail of water, but of course it's only about a foot deep, probably won't read that shallow. My depth sounder was displaying - - last year when boat was in water so something needs replacing. So here is the issue: If the new transducer should have worked out of water, and I have to replace the display unit, I have an opportunity to replace the whole thing lock stock and barrel, or go with a new DS 45 display unit for $270.00, on top of the new transducer I purchased for $80.00. I know some of you are using Fishfinders. There are new units with built in GPSs and speed etc.. My DS 45 is just depth.So what are you folks using? Benefits of different unit's etc .. I need to make a decision soon, it's almost launch time.Thanks,Steve
