Real Costs and Counting
I purchased a '88 H33.5 approximately3 1/2 years ago. I have spent about $10K on maintenance and improvements as follows: Year 1 ($5K)-- Barrier coat, sand blast and coal tar epoxy keel, anti fouling paint, 16K btu AC/Heat,re- finish exterior teak, repaired leak in rudder. Year 2 ($3K)-- Compression post replacement, refinish cabin sole, replace lifelines, rebuild head, upgraded bilge pump, installed Nicro solar ventilation, replaced VHF, installed stereo and speakers. Year 3 ($2K)--Haul out for bottom bottom maint., replaced batteries with AGM batteries, replaced charger with statpower smart charger, Norcold AC/DC refrig. AND Counting ($?)--need to replace speed & depth instruments, replace canvas, clean and maintenance on sails, maintenance on Yanmar including clean/replace mix elbow, clean heat exchanger, replace therm- ostat, add temp&oil pressure guages, possibly fabricate anchor roller and install windlass, possibly replace cockpit and interior upholstery---- and finally routine maintenance!
