I had more questions but limited time and went away without asking them. I'm going to go back but I figured I could ask a few things in the meantime from the hive mind here.
Is this butyl slapped on as a temporary sealer? The boat appears quite dry on the inside (no rusty bolts or stains that I saw at ALL), but this seems messy. I could re-bed it myself at a later date, but is this necessarily "bad" if you intend to fix it moving onwards (owner says new hardware is on hand, just lack of time prevents install which, you know, I sympathize).
Second, I was just looking through some more of my pictures and ... are these bolts upside down? Not sure if this is normal or just sloppy, I don't see any bedding squeezout there either. Again, something I could definitely re-bed myself later, but just wondering if this is a Catalina peculiarity. You can see ones further down the deck are the more expected orientation.
Thanks. I'm reading (and re-reading) "Inspecting the Aging Sailboat" but some of these things are still a little bit of a mystery - although each boat visit clears up more and more things.
