Whale cockpit shower
Dec 18, 2016
41
Hunter 306 ft lauderdale
has anyone had to take apart a Whale cockpit shower. i took the shower head off tried to run water thru, no luck. I took the hot and cold knobs off and the stem looks like a head head bolt but plastic. Dies anyone know if i can unscrew them and hopefully it is just clogged in the valve. thanks
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
A photo of the Whale cockpit shower would be helpful to confirm model. Or match the model from Whale (link below) and contact them or worst case replace the shower for $138 from Wholesale Marine (link below). Maybe the attached instructions and manual can help.
Oh. I read the subject and thought you meant
I wondered why the boat was getting so close to the Whale. Those experiences often come with the smell of dead fish.
Sep 11, 2011
419
Hunter 41AC Bayfield WI, Lake Superior
It is likely a kinked hose behind the panel. There is a thread out there about this. If you have access from inside the boat take a look at the hose.
