what you need to realize is that the component of the system called the toilet or head, can be of several different types, models and sizes, but they are basically kind of all the same for marine or land based vehicles in that they have an intake line and use water to flush and they have a discharge line for the outflow of the waste.
where the separation in marine and RV is the greatest is the way the 2 different systems must be installed.
RV installations are simple and easy to do... as simple as any household installation.
but a boat installation has other considerations that need addressing...
the rocking and heeling motions of the boat...
the fact that the head may actually be installed below the water line...
and no matter if it is above or below the water line, a breach in a line could sink the boat....
the somewhat complicated plumbing of the system (the toilet is a simple object, it has an "in" and it has an "out")
the strict laws regarding proper valving and lock outs...
and so many other things different than what you are dealing with.
thats why you need to stick with an RV site for the proper instruction for what you need...
just because an object, no matter what it is, has been approved for marine use, doesnt mean it will be installed in an RV the same way a boat would have it installed... a LOT of things are installed different for marine applications, than the same object would be in a land based vehicle install. a LOT!!!
