Leekey 23
I had a simlar problem with my O'day Tempest. There was water pooling in the 1/4 berths and on the floor next to the porta potty. I tell you what I found and how I fixed it. The leek on the floor was from the spreader light connection on the deck. Thats on leek sealed, now for the tricky one. The water in the 1/4 berths had me puzzled for some time, then I decide to try a repair.(after all the boat wasn't going to fix it'self) I pulled off the outer flexable rubrail to expose the ridged rail underneth. I used Marine GOOP to seal the gap between the ridged rail and the deck. I figured out that the water was getting in between the deck and hull and running down into the 1/4 berths. After the ridged rail was sealed I haven't had any more problems. The one drawback you'll find is that the flexable rubrail will shrink once it is pulled off. I wasn't able to reuse mine and had to buy another. I know this was long, but I wanted to make sure it was clear how the water was getting in. I hope this helps you. The only other piece of advice I have for you is try to really investagate throughly and pin down the point of entry. Best of Luck, Jason Mick
