Wet Bow.
Noticed the same problem when I bought my H34 in 1997 and put it down to a leaky hatch. After the fall pull out, I removed the bow sole to dry, strip and re-varnish during the winter. The boat was then relaunched in the spring before I had screwed the sole back into place. That was when the real cause of the wet sole became known. The boat yard called me urgently as they found that the two front screw holes had been drilled right through the hull bottom and water was squirting through the holes like a fountain. Water had been leaking slowly by the screws making the sole wet. The boat yard re-pulled the boat, ground out the holes and filled them with epoxy. Later I carefully fitted new short screws and have had a dry bow sole ever since. No idea who drilled the offending holes.
