Wet Rudder Avoidance / Preparation Question
K
Ken
There have been a few questions/comments about wet rudder repairs. What about a brand new Beneteau fresh from the factory? My thought would be to apply 3-4 good layers of Interprotect before it hits the water. Will that give a longer life to the dreaded wet rudder problem? Thanks Ken
Jun 13, 2004
42
Beneteau 361 Stockton, MO
Wet Rudder
As I understand it, a wet rudder is primarily a problem in that it can cause the stainless steel inner structure and stock to corrode and fail. Your Beneteau doesn't use any steel in the rudder's construction or stock. There is information about it's construction on their website. That said, I'm sure as a part of commissioning the hull and rudder would get a good barrier coat.
Dobber
Dec 13, 2006
8
Beneteau 351 Wilmington Delaware
My wet rudder
I experienced a water logged rudder in my 351 after 3 years. Two of the first three years were spent in the water all year. I noticed the thing leaking when I pulled her out. I think my problem was enhanced by a shallow slip that worked the rudder in the mud on lower than usual tides. I drilled the thing in key places and sucked the water out using a strong vacume cleaner prior to freezing temperatures. I repeated this process several times, then checked it dry by blowing compressed air into the higher elevation holes I drilled in the rudder. When she was all dry I pressure filled the holes with epoxy resin, sanded and gel coated the area. I used a small diameter drill bit and went no deeper than the voids filled with water. Close examination of the water intrusion revealed osmotic blisters under the gelcoat. I specifically attacked these areas with my technique. I performed this repair after I spoke to Beneteau customer service. Keep in mind I made my repairs in 1998, so Beneteau might have a better technique by now. I also noted Beneteau changed the design of their rudder in the late 1990's with this problem in mind. Good luck.
Dobber
Dec 13, 2006
8
Leaker
My 351 had a composite rudder stock, not a SS stock. The rudder is not solid as some may think. Mine leaked by osmosis.
