Hi all,
My Cat30 has a DC refridgerator with a drain that doesn't drain. The unit works very well and maintains 40 degrees easily. However, there is a problem with water collecting at the bottom.
I've cleared the line several times but still find about a half inch of water from what I am sure is condensation sitting in the bottom. The drain hose connects to the sink outlet and all is clear. I've even pushed a snake through to the thru-hull and all is well.
Does anyone else have this problem.......and a possible solution?
