Manny:
Thanks for the info that the core around the mast step was balsa.
Regarding when you tapped into your cockpit floor it "spit out soggy wood": This is very different than my situation where the wood was still in good shape. I would think that if the core is too far gone, then a complete peel-away of the top skin and rebuilding the interior with new wood (or other material) will be the best route. I found a post that I made about 1.5 years ago when somebody else was looking for another owner's experience with cockpit sole repair. Might contain something of use:
Dear Sailtip: I did repair this past summer the cockpit sole section under/around the pedestal of my 1980 Cherubini H36. The core was a mosaic of individual plywood squares. The plywood itself was not rotted and was still firmly attached to the upper and lower fiberglass skins. But probably because of years of H20 ingress, the glue holding the plywood layers together had failed. Took several hours with a sharp wood chisel/hammer and then an orbital sander/grinder to get the all plywood off of the fiberglass. I'm a newbie to sailboat maintenance, so best to make your own assessment about the following which is how I went about my repair. I'm sure that others have better methods, but maybe you can find some nuggets of info that might help. I don't know if the Cherubini 37 cockpit sole is constructed similar to the Cherubini 36. On my 36, after removing the pedestal and other mounted hardware from the sole, I used a cutting bit on my dremel tool to neatly cut around the top layer of fiberglass at the interface of the non-skid and smooth surface. Then I was able to peel off the top section... (didn't come off easy). Cutting out the bottom from the limited space underneath the cockpit floor seemed just too difficult. I removed all the old plywood core and roughed up the new mating surfaces. I put duct tape over the holes into which the pedestal and grab rail bolts went, both on the top and bottom skins. Maybe not necessary, but from underneath, I attached several long/straight 2x4's using deck screws through the wood into the lower fiberglass skin. I did this to bring the lower skin to a reasonably flat condition since the pedestal and steering sheaves are mounted in this area. I cut off the portion of the screws that protruded up through the fiberglass. Later, after the epoxy work had been completed, from the bottom I was able remove the screws and then the 2x4's. I drilled lots of 1/2" holes in the replacement wood. Then I flooded the bottom with West Systems epoxy and layed in the new wood. Pressed it down until epoxy oozed up through the holes. Then flooded over the wood with more epoxy. Then brushed a layer of epoxy to the underside of the top skin to wet it. Then layed and centered the top skin on. Jiggled it around for a while so the epoxy would flow and adhere. An issue was deciding how much epoxy was needed to flood the space so that all plywood/fiberglass would be mated everywhere, but that lots epoxy wouldn't ooze out. The fact that the boat was not completely level also complicated. I put heavy stuff on the top skin to keep it compressed and level on the new core. After the expoxy had set up, but was not yet rock hard, I shaved back the high spots that had oozed out. I found that having some epoxy filled syringes on hand was useful to neatly fill the gaps where epoxy had not filled to the top. Since the orignal cut to remove the top was at the smooth/non-skid interface, and with careful shaving the excess epoxy, and sanding with a small block, and with two-part polyurethane paint to finish it all off, the repair is not readily noticeable. One item that I would vary if I ever do this repair again (hope not), is that I should have made the core area around the pedestal maybe about 1/8" thicker than at the edges of the repair area. After a rain or washdown, I have noted a small 1/16" deep puddle in the center around part of the pedestal base. If the center thickness had been bowed up a bit, the water would run off and into the cockpit drain. regards, Rardi
