L
L and W
The Westerbeke W10/Two in my '84 Hunter 27 is dying after 30-40 minutes of smooth running. I can let the engine rest for 10 minutes, then it starts right back up and runs great for 10 more minutes before dying again. I replaced the primary fuel filter and gaskets, drained the sediment bowl, refilled the filter container and bowl with clean diesel. I pulled off the injector fuel tubes to verify that fuel was spurting into the injectors. After doing all that, the engine started right up and ran great for 35 minutes, then died. Should I start back at the fuel tank and try to inspect/clean/replace every hose and fitting?Thanks!
