I have last fall purchased a new to me, 1994 Morgan Catalina 38 center cockpit, and we love it. It has a Westerbeke 38 engine and susposedly, we should be able to heat domestic hot water from the engine. I have tried everything I can think off to get this working, but no luck. Can anyone offer me any suggestions. Here is what I have done: Replaced the hoses running from the engine to the water heater; Removed the water heater and flushed heater and hot water coil (all fine); Replaced the valve and housing on the engine that deflects flow to hwh (with oem parts); Ensure antifreeze is always topped up; Bleed system numerous times; Note, engine does not run hot, but settles in a about 180 degrees and will run forever at that temp. I thought of the water pump, but the engine is not overheating. We get lots of hot hater when plugged in to 120vac.
This problem is driving me nuts. Any help would be greatly appreciated.
Mike B.
Mike B.
