How close to hull speed does your Westerbeke get you? Just asking because say you achieve 90% of hull speed with it, more HP will get you closer to 100% but that might mean only .5 - 1.0 knot or so better through the water. A more powerful power plant is most useful for getting that extra headway when pressing into the wind and/or chop. Or accelerating/braking quicker. But on a calm day, maybe not all that much change in max through the water speed can be realized. That extra 1kt however might make a real difference if you heading up against a 3-4 kt current. Now you are going say 3kts over ground instead of 2kts. Either way its a slow battle! For me the current demons are courtesy of the tides pushing into relatively narrow SF Bay water channels. Often 3.0 - 3.5 kts max current under the bridge. If flooding and also against the wind, close-hauling out the gate sometimes can't be done on my boat!
