Westerbeak 50 - 48HP Fuel Consumption
  • Thread starter Jerry Clark H356 SV Persistence
  • Start date
I am helping a friend take a Cabo Rico 38 from Kentucky Lake to Charlotte Harbor down the Tenn Tom in early November. He has not motored or sailed the boat very much since he got it and does not know the hourly fuel consumption at 2,700 to 2,800 RPM at cruise. He has 105 gallons of fuel. Does anyone know the apoximate hourly consumption? Thanks
Ross
Jun 15, 2004
14,693
Allow 1 quart per 4 hp per hour
That is pretty much standard for diesel engines. That is not rated hp but actual shaft hp delivered.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I use 1/2 gal per hour
For my Westerbeke W30 in my 32 Oday cruising at 6 knots and that gives me a rough idea of about how much fuel to add to the tank and I been checking this with the not so acurate fuel guage but its close enough. I would guess that the W50 is close to this GPH
Thanks for the responses!
We're leaving Kentucky Lake on the 28th of October, down the Tenn-Tom to Mobile then to Charlotte Harbor. By the time we get down the Tenn Tom, we'll know the range well, but we wanted some idea before leaving. Thanks to both of you.
Tartan 37 Gore Bay - Lake Huron - Canada
Far to high!!
At the rate of 1 quart per 4 hp I should be using 2.5 gals per hour. I use more like 1 gal per hour with a Westerbeke 50.
Feb 6, 1998
11,701
I have a Westerbeke 44B Four
I have a Westerbeke 44B Four and burn roughly .6 gal per hour at cruise which for me is 2200 rpm's. At 2700-2800 I'd think you could be burning as much as .8 - 1 gal per hour.
Ross
Jun 15, 2004
14,693
Steve, The fuel comsumption rate on any diesel
engine is determined by the power consumed not the rated HP. You may have a 50 HP rated engine but at cruising speed you aren't using 50 hp. Probably closer to 15 hp.
