Tim
I rebuilt my entire sanitation system this past off season. I bought the 1 1/2 inch elbows for this at West Marine. I noticed that when I assembled the hoses that the elbows seemed a little undersized but after heating and struggling with the hose to get it onto my bronze thru hull I did not give it much though. I figured I could compress the Sealand hose enough to make a seal. Not so. When I pumped water thru my system, just about every elbow leaked even with double clamps. I even tightened the clamps to the breaking point and they still leaked.I went to my local WM and we measured various elbows, tees and other fittings and almost all measured 1/16th to 1/8th undersized. The ones that were a correct 1 1/2 were a slightly different color(maybe different maker). They are going to refund my money but of course all my labor is lost and I must pull the whole system apart and reconnect with fittings I bought at Hamiltons here in Portland.I suspect that the fittings might work if you heated the hose enough and clamp it while hot but I am not willing to take that chance.Tim R.
