problem fixed
I followed Peggie's advice and removedthe sender.  The sender is a perforated cylinder, about 2" in diameter that hasan internal, rod running up and downits center.  There is a slideron this rod that must connectto a transducer.  Somehow the slidergot stuck.  I freed it by sloshing thesender in a bucket of clean water.Of course, before I did any of thisI had the tank pumped and then Iflushed it about three timeswith clean water. Nevertheless,this job ranks near the bottomof things I want to do to maintainmy boat.  The bad news is thatI expect the slider will getstuck again and I will have to repeatthis task.
