Well, I think she's about done... and I made a mistake.
2,500
Oday 192 Lake Nockamixon
Last night I visited the boat at the lake, after a horrible grey, damp, slightly chilly weekend. I was disappointed because Friday after work, I had plans to finish projects! But then a friend visited, and that opened us up to chatting with a few other people on the dock, and next thing you know, I didn't get everything finished.
But as of last night, I think I can honestly say I've finished all my fitting out projects.
Friday, I installed my external style Mast Gate. This makes up for my second sail of the season, when I dropped my sail stop and it plink plink plopped overboard. While I was at it, I ordered and installed one of Tom Luque's quick release stops, so that my sliding gooseneck can be easily adjusted, instead of the wingnut stop that came with the boat. I also finally cut my downhaul/Cunningham to length.
Sunday night the Admiral made me go visit the boat, because I was far too grouchy. We only sat on it for about 15 minutes because it was damp/misty and she got very cold, but it was like getting a fix - I was happy and pleasant the rest of the night.
So, last night I finalized placement of my topping lift hardware. Doh! I forgot to take pictures! Anyway, I have a single block hanging from the masthead on 3/16" polyester. I attached a single with becket to the endboom strap that the backstay pigtail clips to. The line runs from the becket up to the hanging single, back down to the single, forward through 2 eyestraps used as fairleads, to a fairlead clam cleat screwed to the boom a few inches aft of the reefing cleat. The topping lift runs just above the eyestrap fairlead for the reefing line. This positioning keeps it close to hand when striking sail or reefing, yet just out of the way of the reefing cleat. I also tied the hanging single high enough that I can crank the boom up to give me standing headroom in the cockpit for motoring and such.
I also shortened the main outhaul line. Fewer dangly lines is good.
But I fear I have made a mistake. Over the weekend, I went to gobs and gobs of trouble to remove old stitching and the rotted remnants of velcro from the hem of my main cover. Then I re-stitched zig-zag where needed with UV resistant polyester thread, and sewed new strips of velcro between the common sense toggle fasteners. I think this was a big mistake, because I just read that having loose closures such as common sense fasteners or clips allows more airflow and reduces mildew. So, it looks like I'll get to spend some windless day with a seam ripper, picking out all the stitching for that velcro to remove it again. DOH!!! :doh::doh::doh:
Yeah, and I guess the one final thing I need to do is to take some of the nylon twisted line I have and splice some new dock lines. I had just bought some swanky double braid dock lines to keep on the boat, for raft-ups and such, but I found I needed to use them. Besides, if I custom splice lines to length, there's less spaghetti monster around the dock cleats.
Brian
Ward H
Nov 7, 2011
3,788
Brian
Brian,
It sounds like your hanging single block is tied to the TL just above the boom or is it up near the mast head?
I plan on running the TL line from the mast head down to a block on the end of the boom through fairleads to a cleat. Wouldn't trust a clam cleat but a cam cleat might be a good idea.
Was wondering why you used two blocks. For ease of lifting the boom?
Nov 9, 2012
2,500
Yes, my single from the masthead hangs just above as high as I want the boom, so, yes, at boom level. I though of a cheek block at masthead, but I didn't really need it, and it would just be a bit more weight aloft.
My single with becket at the boom end is really serving the same function as an eyestrap and cheek block mounted on either side of the boom. I was able to connect to the pivoting end strap (which used to be clipped to the backstay pigtail topping lift) rather than drill and mount both a terminal eyestrap on the port side of the boom, and the cheek block on the starboard side to run the line forward to a cleat. So far, I'm not sure if I like all the flappability of my system, but I can always move to strap and cheek block if I need to.
You bring up a decent point on the clam cleat - I had my rudder uphaul cleat let go once at a bad time. But since I have a fairlead style clam cleat, I'll tie a stopper knot in the end of the lift adjuster, and that will prevent the cleat letting go and the boom falling into the cockpit. But I have nylon clam cleats for my outhaul and reefing line on my little boat, and they work ok. I have an aluminum clam cleat for the topping lift.
So, yeah, tonight, I guess I ought to take a picture...
Brian
Ward H
Nov 7, 2011
3,788
I have an open horn cleat on my boom I plan on using for the bitter end of my topping lift. I had read about running the line through the horn cleat, then tie a knot so when the knot pulls up against the cleat, the boom is at it's low point. After dropping the main you pull in the TL line and cleat off so the boom is high enough. Not sure if I explained that well.
I just need to get my mast back up and boom mounted so I can figure out the TL, reefing and such.
Yes, pictures please.
Nov 9, 2012
2,500
Ward, I understand what you mean about the cleat. That's actually a really good idea. I've heard some folks use the same horn cleat for both clew reef lines in a dual reef sail. I dunno. I had been using the reef line cleat for the topping lift, out of temporary necessity, and I hated having two lines on the cleat...
I'll see if I can get some pics for you this weekend. I had a great night out on the boat tonight, but I need to get on the bike if there's any more good weather the rest of this week.
Brian
