Bill Leathen
Somehow, the top sheave in my mast on my Hunter 23 wing keel boat pulled downward and tore out the pop rivet holes. I have removed the sheave and plan to have the area where the pop rivets welded back so that there is some metal and re-drill the holes. My question is what weld alloy should be used to weld the holes. Can I assume the mast is made with alloy 6061 aluminum. Will weld rod alloy 4000 or 3003 be acceptable for the weld? Any advise will be helpful.Thanks Bill Leathen - bleathen@aol.com
