I had another stanchion break on me. Both times it was a clean break at the weld. Would a beginner welder be able to make a stronger weld or should I just replace it with another used one?
I’m not sure what is on your boat but most of the posts are fairly thin walled stainless steel. Not to say a “beginner” welder couldn’t weld that material just saying it’s not as easy as welding a couple of pieces of “steel” together.I had another stanchion break on me. Both times it was a clean break at the weld. Would a beginner welder be able to make a stronger weld or should I just replace it with another used one?
Do you have a MIG or TIG welder? Do you have stainless rods, or wire as applicable? Do you have some similar materials to practice on before you try the actual repair? If the answer to each of the above is yes, then you might be able to do the repair. But welding stanchion tube to base plate isn't super easy, so it's not a slam dunk that a beginner can pull it off.I had another stanchion break on me. Both times it was a clean break at the weld. Would a beginner welder be able to make a stronger weld or should I just replace it with another used one?
That answers my question. I'll go ahead and purchase another oneBut welding stanchion tube to base plate isn't super easy, so it's not a slam dunk that a beginner can pull it off.
