i know this subject has been beat on before but....i personally am satisfied water is not coming up from my keel. while it was out last winter i had used a shop vac to suck the area between the hulls dry and after a good snow, (i only had the cockpit area covered), i found water in the keel bolt areas again. so, its coming from somewhere up top. i am going to go throught the anchor locker drain shortly and make sure that's not leaking. also, while it was out last winter i cleaned, retorqued the keelbolts, recaulked the keel seam, and used a couple if coats of interlux barrier over the caulk and keel.while in the water, the water in the keelbolt area only comes up a few inches and stays steady....if it was coming from the lake it would continue to rise. maybe i'm a bit anal about this small amount of water but i expect the bottom of my boat to be dry!so....i'm wondering, is there room between the inner and outer hulls for one of the small bilge pumps? say, the area back under the step where it rises up a little. the smallest rule pump is only 3 1/2" tall and i could drill for the outlet hose through the fiberglass "rise" at the end of the double hull and under the aft bulkhead. (The one that seperates the laserette area under the cockpit from the salon), and run the hose out the transom and then wire the pump and cover the hole i made to mount the pump. has anyone mounted a pump under here? my other option if there isn't room might be to mount a small deck wash type pump in the laserette area with the intake run through the same placed hole and the output out the transom. my next step is to pull the rub rails and rescrew and reseal between the upper and lower hulls....although i see no evidence of water coming in here. looks like there would be water stains on the wall carpet if this was the source of this much water.tia~william
