J Jeffrey Condit . Oct 29, 2012 3 hunter 340 swantown olympia Nov 19, 2012 #1 out of the blue..... no jets taking off..... no tap tap tap...... just cold air......where do I need to start.....
P propellanttech . Oct 23, 2012 42 Hunter 35.5 Adger, AL Nov 19, 2012 #2 Jeffrey Condit said: out of the blue..... no jets taking off..... no tap tap tap...... just cold air......where do I need to start..... Click to expand Do you have a panel if so are there any indicators? If not, I would start with the fuel filter, if you have one. After that, make sure it's getting fuel, then glow plug. Do you have the manual for the Webasto 3500? James L
P propellanttech . Oct 23, 2012 42 Hunter 35.5 Adger, AL Nov 19, 2012 #3 Here is a good thread on the Webasto: http://www.ybw.com/forums/archive/index.php/t-258755.html James L
J Jeffrey Condit . Oct 29, 2012 3 hunter 340 swantown olympia Nov 19, 2012 #4 thanks James...... I just down loaded the manual and am going to check your suggestions
P propellanttech . Oct 23, 2012 42 Hunter 35.5 Adger, AL Nov 19, 2012 #5 Jeffrey Condit said: thanks James...... I just down loaded the manual and am going to check your suggestions Click to expand I usually suggest someone download the manual first. Most are available online. The unit is quite simple really.......works just like a kerosene turbo heater with an added plenum chamber. Not too much to go wrong. Also check out the thread, they say running on low will soot up the combustion chamber, which seems to be quite normal. James L
