weather helm
Julius
I recently sailed with a friend on his catalina22.I have never sailed a boat with so much weather helm. He said this is his second cat22 and both had a lot of weather helm.Does everybody have this problem???
F
FINZZ
sail trim
how were the traveler and mainsail set??? very easy to dump the weather with an adjustment of traveler and main....
Mike
What were the conditions?
Was the wind strong? How much mainsail was he carrying? I have a C22 and if there is too much sail up for the wind speeds, she wants to heel over and round up. I usually put the first reef in the main when there are steady whitecaps, around 12 mile winds. The boat sits flatter and has a more balanced helm. My speeds will also pick up because I can maintain my momentum. Not having a little weather helm isn't safe.
David Williams
Rudder
Did you have a kick-up rudder, and was it all of the way down and pinned? After my Catalina rudder broke, I purchased a Ida Sailor plastic rudder off this website. You wouldn't believe how much better the Ida Sailor rudder works. I never have excessive weather helm. David
Jul 8, 2004
157
- - Pinedale, WY
Also check Mast
Julius: Weather helm on my 1975 C22 is usually overcome by setting the shrouds and forestay properly during the setup stage, so that the top is about 6 in. aft while bestilled in calm water (determined by putting a weight like a wrench on the main halyard before putting on the boom). In strong wind I can also bend the mast aft a bit with an adjustable back stay. The result is to move the wind forces aft which removes weather helm. But you can overdue this so that instead of slightly rounding up when you remove your hand, rather you round down which could get one into a little trouble I suppose. Best to set it up so that there is just a little rounding up on the helm while tacking. Balancing the main against the jib as others mention is also important. I was taught to set the jib on a tack just right so it is full and nicely curved but close to losing the wind (telltales streaming back parallel to water), then to set the main in a very similar position so that their curves are similar and the slot between open. From there you can adjust just a little for helm pressure. Dick K.
Sep 21, 2005
297
Catalina 22 Henderson Bay, NY
Ida Sailer
Dave, I second the Ida Sailor rudder comment. I purchased one last spring, and it is great. I like the feature of raising the blade all of the way out of the water when you are in your slip. No need for painting the blade. Also balances the helm very nice. Dale
