When sailing Bneteau 373 in 20 - 30 knots of wind, I am experiencing an abnormal amount of weather helm even with both the main and jib reefed. Any suggestions or comments?
Before you get off onto changing the rig geometry....
How is the sail shape on that main? Really?!
Given that the boat was decently designed, it should sail without excessive helm if you have reduced sail area for the wind pressure. At about 25 kts+ you probably should have the second reef in, for starters.
When the first reef is in, can you get the clew pulled right out tight and onto the boom top? Is the sail fairly flat with the draft center or forward a bit?
Also, when you reef that jib, what size is the whole jib?? For instance, if it's a 135 and you are rolling in a lot to get it down to about a 100, the shape is likely terrible and the luff is fat and slowing you down... and causing you to heal more.
After having issues with our faithful 135 and never getting the boat to balance just right in winds over 18, this year I went with a new 95% with vertical battens. With one reef in the main we go to weather at over 7 kts in 22 kts true. In 17 kts, we go to weather with the full main, flattened, and can maintain over 7 kts.
After decades of believing that large genny's are great to have, I am a convert to smaller ones that maintain a decent leach profile with the right battens.
Something to consider...
(Small world -- there's a Bene 373 just down the dock from me. )
