We are discussing mast rack, heeling and weather helm. In order to deal with those subjects it helps to have a little background as to what they are about.Some sailors think that only the rudder turns the boat. It does but so does the mainsail although not as well or quickly as the rudder. The more you tighten the leech of the main (eliminating twist) the more the wind turns the sail. This turning of the wind is like turning the rudder. So sail shape contributes to weather helm. A lot of sailors don’t like weather helm but there is nothing wrong with weather helm. In fact, it is a good thing especially in light wind. Heavy wind is a different story. Weather helm in heavy wind can be a pain.How much weather helm is desirable? When sailing upwind about 3 degrees to 5 degrees is just about right. Why is that? I don’t know the scientific answer but experience has shown that at those degrees the lift from the rudder exactly compliments the lift from the keel and most boats sail best. You might be able to push it to 7 degrees but beyond 10 degrees is too much because now the rudder is creating too much drag.How do you measure weather helm rudder degrees? Simple, just center your rudder and put a piece of tape at the top of the wheel. Now we want to see whether you or your boat has a weather helm problem. Next time your out sailing closehauled and the wind is about 5 knots, take your hands off the wheel and see what happens. If everything is in balance the boat should almost sail straight and slowly head into the wind. Only the slightest bit of rudder is necessary to bring it back to a straight line. At 10 to 12 knots of wind do the same thing and if everything is right only about 3 to 4 degrees of rudder will be necessary to bring it back to a straight line. In 14 to 16 knots of wind, it will take about 5 degrees to bring it back to a straight line. If your boat performs as above your boat does not have a weather helm problem. If it does not perform as above it is the fault of the skipper and the trimmers.
