Weather helm is common to most boats
Excessive weather helm can be a symptom of a larger problem (mis-aligned or bent components, out-of-tune rigging, etc.). Moderate weather helm is present in almost all sloops (maybe all) to some extent. Adjusting sail trim can help reduce it. Ease the main (or drop the traveler) and trim the headsail. Weather helm is caused by the forces acting on your hull and your sails. The way I understand it, wind blowing against and around your sails creates lift, like an airplane wing. This lift is spread out over the surface of your sails but creates what they call a "center of effort" which is the spot on your sails where the average of this force is. Imagine an X at the center of effort (CoE). The CoE is probably about half way up your main and closer to the luff than the leach. Sail trim will move the CoE to different spots. Think of your fin keel as a pivot point. If the CoE is behind your fin keel the stern is being "pivoted" away from weather and your bow is being turned into it, weather helm. Moving the CoE forward with sail trim reduces these "pivoting" forces thus reducing weather helm. The other thing that happens, particularly in gusts, is your boat will heel. When your boat heels the CoE can move past your leeward rail and now be over water instead of over your deck. The CoE is now pushing your leeward side harder than your weather side, turning you into the wind, rounding up in a gust. Racers drop the traveler in gusts to prevent rounding up and making it easier to hold course. Once the gust has past they pull the traveler back into position.Think of weather helm as a safety feature built into your boat. If you are overpowered by a gust you automatically turn into the wind, reducing it's effect on you. If you are beating to weather and got hit with a gust and your boat didn't have this built in feature the gust could turn you off of the wind, putting you on a beam reach and making you much more vulnerable.OK guys, did I get this right?Toms/v Orion's Child
