In the past 30 minutes of reading other posts I've learned about what I experienced my last time out on my H26, my 5th time out with the sails up.
The weather helm effect was most apparent on a "beam reach to a "broad reach" 5 ft swells were coming in of the stern on the windward side.
I thought it was the combination of the swells and too much wind in the sails that kicked me around into wind with the water line coming up to the gun rails on the leeward side. I could fight it off when he started it seemed by pumping the tiller and point her more into a broad reach.
I had the traveler set in the middle. (should this have been moved to the leeward side? )
I know I must sound like a complete idiot but I've got to start asking questions. It was a just a little bit scary. The winds were moderate with gusts. I need to learn how to handle this.
The tackle/main sheet is connected to the middle of the boom.
The boat has a roller furler jib.
The tiller was more to the windward side when sailing.
I'm trying to think of all of the settings that you the reader might need to help me get a handle on eliminating this effect (if possible). Or, what I should do during the event to bring the boat back under control.
It swung me once right into irons. If these had been heavier winds I might have been in serious straights.
I think I want to know what I should be doing with the main. I should be flattening it if what I read is right but I want to be able to unload it. I don't think I should need to reef in the main but if so I need some idea how to do this.
This is offshore sailing on the Pacific side of Panama
Enough said at this point..
