Dale I
I received from West a pre-spliced spin halyard with wichard shackle that was 'custom' length as it was cockpit-led and longer than their standard ones. Due to the bracket/sheave arrangement in my spinnaker sock I needed a larger inside dimension on the halyard shackle than was provided on the new halyard. This led me to discover that my 3/8" Sta-set halyard, which is rated at around 4400 working lbs, has a wichard shackle that is rated at 2640 lbs. How do I determine the loading imposed by the spinnaker and whether that shackle is up to the task? Am I negligent to 'assume' that hardware that is incorporated into a 'packaged' halyard would be of a similar load rating? The symmetrical spinnaker is of mystery origin and make that came with the boat, (C&C 34). Replacement of the new shackle would require the removal of the 'bar' in order to get it out of the eye splice....its a nice job that they did....just seems, maybe a little undersized.
