Weak starting cranks
91
Catalina 30 MKIII Mantoloking Shores NJ
I have a problem....finally got Hallie Luna into the water and rigged this past weekend. However, I have had a hard time getting enough cranking power to start the engine. I have 2 new (1yr old) group 27 deep cycle batteries. They a fully charged. Used them all last year with no trouble.....now....I need to crank engine with both batteries.....could it be the starter?
I am a little baffled. Any thoughts would be great.
Thanks
Jul 7, 2009
218
Catalina 30 Mark I Stockton, Mo
What engine do you have, gas or diesel? Sometimes diesels have some trouble cranking, and you have to pull the decompression cable to allow it to crank.
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
Check your electrical connections at the battery and starter. I had a problem with my starter at the solenoid on my C27. Took it apart and cleaned and rotated the connections. On another boat I had a problem with the ground connection to the engine.
On my newly acquired C30 I also have to use both batteries to start. I don't know the age of the batteries but will be checking my connections first.
mortyd
Dec 11, 2004
952
Catalina 30 easy living
if it's a diesel, i used to have all kinds of trouble with my 25xp until one lazy day i decided to read the manual - dumb me for not reading it from day one. it clearly said 60 seconds of glow plug - and i haven't had a problem since.
May 23, 2004
3,319
I agree with checking the electrical connection.
If it is a MKiii, It is diesel and, unless changed out for another engine, a Universal M25XP.
Have you tried starting the boat at the solenoid? If it starts up there well, then you may have an issue with the start button.
The engine ground can be a problem. Sand it and re-connect it.
One other thing that can cause you issues is the engine shut off not being put in all of the way.
Did you have enough water in the batteries? You should also check for dead cells (you could have a bad battery).
Oct 16, 2005
91
Thanks for the advise !! I will check all of the above things this saturday,.
I do have a Diesel, its a M25XP. I usually had to hold glow plugs for about 10 to 15 seconds. I will try holding them longer as well.
Thanks again.
Apr 8, 2010
2,151
Gowing and Starting
Thanks again.
We have an '88 M25XP. Glow plugs take about 15 sec. in spring temps, and about 30 sec. in mid winter when ambient temp is between 25 and 30.
As others have said, check all the electrical connections: plus side AND minus side, to and from the battery....
Also, if you have over 1000 hours on your engine, take off the starter and have it rebuilt. (Top bolt will take a wobbler, and maybe a short extension, and some cursing. The other, bottom bolt is easier. All this depends on access to that side of your engine, of course.
You will probably find that, even though it works now, it will work noticeably better after the rebuild.
That was our experience anyhow. Cost was well under $150. -- might be more now with some inflation.
Good luck.
Don't worry about a rebuild if your engine works after you start it. Man, I just hate it when doomsayers come up with this stuff. Maybe necessary, like this: http://www.c34.org/wiki/index.php?title=Rebuilding_the_M25-XP
But, most likely not.
What you really need to know is here, Critical Upgrades:
1. Engine ground
2. Wiring harness
3. Starter fuse hidden under alternator
http://c34.org/bbs/index.php/topic,5078.0.html
You could learn a lot from this, too: http://www.c34.org/wiki/index.php?title=Diesel_Engine
Wander around our website, we have a TON of M25XP information.
Jul 1, 2004
398
Catalina 30 Atlanta GA
Remember......................once the engine has been warmed you DO NOT need to use the glow plug again unless the engine is cold. Just the starter button will do the trick.
Bob
"88 Mark II (M-18 Universal)
Oct 16, 2005
91
Thanks again as always Stu. Bob...I tried the longer glow plug time and it did work a little better. Gonna mess around with it this weekend.
Thanks
Hal
Bob S
Sep 27, 2007
1,805
Beneteau 393 New Bedford, MA
Hal,
I had the same issues when I bought my boat in 2007. The PO had just put in 2 new group 24's from West Marine. I had to cross my fingers and use "both" batteries and she'd just turn over. Stu helped me that year with a complete electrical upgrade like Mainesail has posted many times. The first thing I'd do is replace the stock 4 awg wire to at least 2 awg. Some increase to 2/0. Do it with all the wiring pos. & ground sides. It made a huge difference in cranking speed. It's not a cheap endeavor but one of the best ones I did. At least I don't worry any more that she won't start up Sunday when I have to head home.
mortyd
Dec 11, 2004
952
guys, isn't it s.o.p. to use both batteries for starting? is on my boat.
Feb 6, 1998
11,721
No. If you "need" two batteries to start one of these motors it is only masking a larger issue. That larger issue should be addressed. These engines will literally start on a PWC or motorcycle battery IF properly wired and IF the batteries are healthy...
mortyd
Dec 11, 2004
952
i didn't say i needed both batteries, just i think it makes sense since once i start i will be motoring and charging. so, why the big NO? just like having a little more drip from my stuffing box rather than a little less, can you tell me what harm using both batteries causes?
Feb 6, 1998
11,721
It won't cause any harm unless your house bank is dead and larger than the start battery. In that scenario there is potential to not have enough CA to start the motor. In most cases your starter will like having more CA. If your alt is fed that way then nothing wrong with it but there should not be a "need", cranking wise, to do so, hence the "NO"... I read it in the context of the thread, which is on "weak starting", and I took it as a general need to start on BOTH. As I said if you "need" to start on BOTH you have a problem that needs to be addressed.
You can start on BOTH but you should not need to to get the motor running..
Starting on BOTH
mortyd, you're a regular on this board. Don't know if you read all the topics, but we have been discussing boat wiring for as long as I've been around here. Both Maine Sail and I are proponents of two major electrical improvements:
1. Removing the alternator output (AO) from the C post of the 1-2-B switch TO the house bank
2. Installing an echo charger (or like automatic method) to charge the reserve bank
This makes the 1-2-B switch a "use" not a "charging" switch. It completely avoids the problem of someone turning the switch when the engine is running and blowing alternator diodes.
Starting the engine on BOTH is only necessary if the AO remains on the C post of the 1-2-B switch and you want to charge both banks.
In most cases the reserve bank is always full. Use the house bank for everything.
Here's the information I shared that Bob discussed when we worked on his system:
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: http://c34.org/bbs/index.php/topic,6604.0.html
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
http://forums.catalina.sailboatowners.com/showthread.php?t=137615
it it ain't broke.........
That's one approach.
The one we choose to take is to advise people of their options and explain why & how things work so they can make their own decisions. Too many people have no clue as to how their boats are wired and how the simple and very useful 1-2-B switch works. We hope skippers can learn from our experiences.
Feb 6, 1998
11,721
If all that switching works for you that's great, keep it. But three alts in the last for weeks all toasted by owners misusing a battery switch is but one reason why Blue Sea, Xantrex and others are selling soooo many charge management devices.
