C
Chris
Hi, I've got an H23 and wanted to share this info with the group here:Check the mounting of the rudder on the inside of the transom. On my boat, there is no plate to spread the bolt load. As a result, the lower mounting bracket started to crush the reinforcing board laminated inside the transom. I would recommend rebedding the brackets and fabricating a decent size backing plate for each of the supports.I also have a couple of questions that someone may be able to answer:How thick should the sides of the hull be? I've installed a through hull on the upper portion of the aft hull and the thickness is ONLY 1/8"!!!! That seems awfully thin... Does anyone know what it is on their boat?I need to change the rubber hose connecting the cockpit drain to the bottom of the boat (where the centerboard lines go). Has anyone done that? Is it easy to do and what size hose is that? I assume there is no reason I can't get it from an auto supply place?Last question (that I can think off): Does anyone know if I can mount an inside hull transducer under the forward v-berth or is the hull cored at this point? (I believe its solid fiberglass) Does anyone know how thick the fiberglass is?Thanks a lot!Chris
