jack
My Garmin GPS/sounder is acting up. The Gps is working fine but the sounder part doesn't get a strong signal. It worked fine for a year but recently shows a very cluttered bottom shot and often will not read a depth. I have a puck type transducer and have move it all along the hull to differant locations with no change. The olny clue i have is the battery alarm on the GPS will go off many times during the day. I have it set for a low reading of 11.2 volts. I hired two differant boat tects and both have said the power going to the GPS is fine. Good bateries, Good ground, good power source. i have replace the power cord going to the GPS and no change. I have sent the transducer and the GPS back to garmin and they have said both check out fine. I plan on sending the entire unit back to garmin to have them check it out again but other than that does anyone have a suggestion? thanks, jack
