Waxing at the dock?
303
Hunter Vision-36 Richmond
Our boat need a good washing, polishing and waxing. I have read a bunch of older posts and have a good idea of the proper process and products to use.
Would I be crazy to do this at the dock? Do people usually haul out to wax their boats?
Any body have any tips or techniques?
Thanks,
Mike
7,343
Alden 50 Sarasota, Florida
I am in the minority but have always found it easier to polish/wax the topsides in the water from the floating dock or the dinghy rather than from a ladder or staging.
Assuming you are on a single dock, It requires moving the bow or stern in toward the dock by moving lines to allow easy reach while sitting on the dock and either turning the boat around or using a dinghy for the other side.
Not sure how to weigh the competing dangers of an electrical line (for the buffer) falling into the water vs. me falling off a ladder/staging.
I've done it both ways and can't conclude there is a time advantage to either.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
I have done the hull many times while in the water and I just did it while on a trailer and the trailer route is much easier. I have two dock fingers and move the boat in and out so it can be done. I just get awful sore lying on the dock and playing contortionist.
Mar 16, 2009
303
How long will it take?
How much time should I allow to rub out and wax a 36' boat?
Johnb
Hunter 37-cutter Richmond CA
Please make it a habit to use ground fault protection anywhere anytime. You can get these in line units that plug in to the outlet and have the appliance pulgged in to them.
JEB
Nov 17, 2008
49
Hunter 38 St. Petersburg
I agree with Don on this one. Most of us in South Florida only haul our boats out for bottom paint or maintenance items on the order of once every other year, more or less.
That said, compounding and waxing at the dock is mandatory. The Florida sun really does a number on the finish without frequent and regular washing and waxing.
If there's no boat in the slip next to us, I can turn the boat around and do both sides of the hull from the dock. Otherwise, I'll use the dinghy. The deck is easier.
For how much time to allow, I may well be slower than most, but it takes me most of a day, using a dual action polisher, to wax the deck, cockpit, and transom area, plus another full day to wax the hull. That's just waxing; if there's compounding to be done prior to waxing, it takes me even longer.
In the summer, we allow even more time. The body just can't take being out in the Florida summer heat and humidity for more than two to three hours at a time, so a topsides wax can take us a week or longer to accomplish.
Jun 4, 2004
1,087
I agree with the other comments on time. It has a lot to do with your physical condition and ambient conditions. I can usually do the hull in one day.
Mar 16, 2009
303
JEB
I see your boat is in Richmond. I'm in Marina Bay. I promise I'll use a GFCI. Where are you?
Johnb
Mike,
I am in Marina Bay Yacht Harbor, dock E330.
John Brecher
