Salt vs fresh water.
For the interested:Salt water weighs about 62.4 lbs per cubic foot. Fresh water weighs 64 lbs per cubic foot. The effect is that a boat designed for salt water will float lower in fresh water (displace more weight of water) than the other way round.That said, ALL responsible designers calculate displacement for FRESH water. This means they will float as designed in fresh water and a little higher in salt water. They will also be sufficiently stable in both. I won't vouch for it but I don't think the perceived increase in buoyancy can be THAT noticeable-- maybe an inch or so more of bottom paint showing on a 30-footer. (I could check the maths but I'm being lazy.)My dad would be present for the initial launching of each new Hunter model and the staff would have this running bet. Everyone wagered five bucks on where the boat would float-- an inch high in front, an inch low in back, whatever. My dad always bet on his designed waterline (DWL). 'If that line is where I said it should be, that's my five bucks.' He never lost. [wink]JC II
