water to sinks
Brad Truby
i am trying to find were i pump the water to the sinks i think its a hand pump but cannot find it anywere . thanks , brad
Scott
lift top of faucet
Brad, if you pull up on the circular top of the faucet and pump several times, you should get water. If you don't get water, check your water tank. There is an inspection port in the front part of the cockpit locker. You may need water. My galley pump was inoperable and I replaced it inexpensively with a new one for around $40. Good Luck.
C
Cjuck
water
Changed my 22's fresh water to an electic water pump. It's great, you get a nice steady stream of water.
G
Greg Sweitzer
Ditto
Ditto to what Chuck said. My dealer (bought a new 260 this year) admitted "Hunter has had some production problems" with the hand pumps that came with the boat. I went through 3 before I gave up on them and bought an electric. Next year I will have a nice stream of running water, wheras this year I had no water whatsoever.
