Water Tanks MT or Not???
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
We just moved ourselves and the boat to SW Florida from ND and my Admiral and I are having a discussion on how to manage the water tanks. We seem to do more weekend and day sails than long runs. We carry two 50 gallon water tanks and we normally keep one empty and the other about half. Since we do not top the tank off very often I am concerned about possible growth in both the empty and the half full tank. We did not have this concern in ND because the boat sat in cool water and air temps but here in FL the air and water get much warmer with the potential (I think) to get something growing in the tanks. Is there something I can do to prevent this or am I concerned for no reason?
Oct 20, 2011
127
Hunter 30 Green Bay
Look at an RV site and see how much chlorine they recommend. It doesn't take much..
Hunter 37 C sloop Punta Gorda FL
Yeah, you are concerned for no reason. Google chlorine adds then add appropriate spoonfuls before you Add water. Annually or thereabouts, empty and flush with fresh water plus fresh chlorine. BTW there is chlorine, but no fluoride in Punta Gorda water.
Jun 23, 2013
54
hunter 33.5 tampa
I have a Hunter 1993 33.5 with a 50gal fresh water tank. I have never had a problem with growth in the tank and I live in Florida year round. West Marine has a product that is added to the tank to prevent growth and I have heard that a small amount of bleach will do the same thing, but I cant verify that.
I use the West Marine product and use it as directed.
May 24, 2004
7,174
CC 30 South Florida
The water that we put in our tanks is already purified and chlorinated as it comes out of the tap. No sunlight enters the tank so the growth of plant organisms is inhibited. We find that the water will last in good condition for many months irrespective of whether we leave the tank full or partially full. When we refill the tank we reintroduce water freshly treated. As a matter of precaution we do not drink the water in the tank nor use it for cooking; it is mostly used for showering and washing dishes. To a certain extent we rely on the water heater to kill any organism that may have developed. Fouled water is discolored and stinks so as long as the water is clear and smells OK we use it for washing. We never treat our water and have been doing it forever here in Florida and never had a problem. Now for offshore cruisers and passage makers having a safe and ample water supply may mean a different thing but for day sailing and coastal cruising the frequent testing and treating of the water seems like an unnecessary burden.
Jun 23, 2013
54
hunter 33.5 tampa
Agree with Benny but I do use the West Marine product. And drink/cook with bottled water.
Let me check with my fellow members of the Tampa Sailing Squadron and I'll have more to add....................
Nodak7
Sep 28, 2008
1,256
Thanks all for your help! I feel much more comfortable handling the tanks now.
Nodak7
Mar 3, 2003
710
Hunter 356 Grand Rivers
We annually recommission our water tank in the spring. I put 60 ounces of chlorine in 75 gallons, run all taps until all smell heavily of chlorine. Leave the solution sitting in your tanks for a minimum of 4 hours, preferably 6. Empty all the heavily chlorinated water through all of your outlets. Once empty, I insert fresh water hose into fill port and match the volume in to that out that it takes for all my outlets to be open. I flush the system like this for about 30 minutes, and then taste the water to see how much chlorine is still there, if too much, the repeat flushing until can barely taste chlorine. then fill the tank. Do not tun on the HWH. After the tank is full, I flush all out again, then drill. By now most of the chlorine is gone, but I usually let sit overnight and then reflush all of the tank again. That is going to completely sanitize your system. Last spring, after doing this, I put in a Safeh20 system with two filters and a. UV light. The SafeH20 unit sits after the tank and before the manifold that distributes the water to the outlets and HWH. We use the water for everything we do and have not ever had a problem using this technique. We got water from a number of sources during our cruise to Florida this past winter and had no problems and felt very safe drinking, cooking, washing dishes, showering and brushing our teeth with the onboard water. We carried some bottled water on our offshore portions just in case we developed a leak and lost our water. the Safeh20 system is good for 3 gallons a minute flow rate and our onboard water pump is rated as 2.8 gallons per minute. Look them up on their website and you will find that the unit kills nearly anything that can get in water that is harmful. I will change out all the filters and the uv light late spring. Cot so the replaceable components is about $45 per year. Small price to pay for ultra clean water.
