Water Tank
Oct 30, 2019
2
I've just bought V1394 'Alouette' and am in process of refitting. The
opening to the fresh water tank on bow is ceased. I've tried WD40,
even hammer and chisel but cannot open it. I don't want to use too
much force in case I do some damage. Is there a special tool or method?
Advise would be appreciated.
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi Don,
there is a slot in the cover to tank that you are presumably using a
tool to twist.
The covers to water and fuel pipes can be hard to open after a few months.
I found that if I used a vice grip (adjustable wrench) to grip a piece of
metal the right shape & size to occupy the slot I could get enough torque
to rotate the cover anti-clockwise to open...
John V1447 Breakaway
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
Oct 30, 2019
1,459
I put a torch to mine, with great care, and with a big screwdriver turned with a wrench that did the job.Nicholas Walsh
Nicholas H. Walsh P.A.
111 Commercial Street
Portland Maine 04101
Tel. 207/772-2191
fax 207/774-3940
This email was sent from the law firm of Nicholas H. Walsh P.A. It may contain information that is privileged and confidential. If you suspect that you were not intended to receive this email, please delete it and notify us as soon as possible. Thank you.
Sent: Saturday, September 13, 2008 1:55 PM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Water TankI've just bought V1394 'Alouette' and am in process of refitting. The
Sep 10, 2008
4
Dear Nicholas
Many thanks for your advice. I confess I'd never thought of putting a
blow torch to it.
I'll try it.
Sep 13, 2002
203
I'd start with lots of boiling water and patience.
If that fails I would then remove the fitting from the deck and deal
with it separately.
Alisdair
Oct 30, 2019
1,459
with great care . . . Heat often works on frozen fastenings, as you probably know.Nicholas Walsh
Tel. 207/772-2191
fax 207/774-3940
Sent: Tuesday, September 16, 2008 5:56 AM
Subject: [AlbinVega] Re: Water TankDear Nicholas
blow torch to it.
I'll try it.
May 30, 2006
1,075
I've heard soaking things in vinegar can un seize things.
Not sure how you would do that logistically though.
rb
Oct 31, 2019
163
Not sure if the vinegar would work, but its ingress wouldn't mess up your water tank like diesel or WD40 certainly would. Logistically though its easy enough: - form a dam on deck around the cap using plastecine and fill it with vinegar. IMHO no boat should be without its lump of plasticine (any colour will do) it has a multitude of uses.
Oct 31, 2019
303
Brion Toss Rigging got me onto some stuff called “KROIL” penetrating oil. This stuff is amazing and I have seen it loosen stainless bolts frozen into aluminum masts and also loosen totally rusted bolts. I wouldn’t be without it. It is sold by Kanolabs. I don’t know if it would loosen your water fitting, but it is worth having on the boat anyway. By the way, I’d remove the plastic hose from the fitting before I got too far into it so stuff doesn’t go into the tank. Kano have some other interesting stuff too, but I’ve only tried Kroil.
Chris
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf Of Bob Carlisle
Sent: Wednesday, September 17, 2008 4:44 AM
Subject: Re: [AlbinVega] Re: Water Tank
Not sure if the vinegar would work, but its ingress wouldn\'t mess up your water tank like diesel or WD40 certainly would. Logistically though its easy enough: - form a dam on deck around the cap using plastecine and fill it with vinegar. IMHO no boat should be without its lump of plasticine (any colour will do) it has a multitude of uses.
Sep 10, 2008
4
I actually live in Kenya and my boat is at the coast so things don't
get frozen. Nevertheless heat might move it.
