Water Tank
16
Hunter Hunter 44 Long Beach, CA
I have a Hunter Vision 36. The aluminum water tank under the V Berth is leaking. Has anyone repaired or replaced one of these tanks?
Sure would like to know...
Thanks,
Loris Johnson
Rick D
Jun 14, 2008
7,187
Twice...
...on my Vision 32. The first one started leaking about four years from new. I glassed the seams and got another year before it failed. I had another made with twice-as-thick aluminum. It failed after three years. I put Vetus water bladders in. Worked fine. I didn't know about Ronco at the time or I would have found something that would have fit. That's where you should go to find something that will work for you. Good luck!
http://www.ronco-plastics.net/index.html
PS: They are in Tustin, so you save the shipping
Dec 2, 1999
15,184
Our HunterVision 36 has a poly tank under the vberth. I have no idea how anyone would ever remove this unit.
I have heard about some coating products that can be used in water tanks. Maybe something like that would work?
Jul 8, 2004
155
Hunter 33.5 Portsmouth VA
I have a 1988 33.5. The original aluminum 52 gal water tank under the vberth started leaking shortly after we bought the boat in 2005. I tried unsuccessfully to patch the tank with epoxy.
I contacted Hunter and they gave me a procedure to remove the tank, the name/address/phone of the original tank manufacturer and also sent me a .jpg drawing of the tank. I really did not want to put in another metal tank so I contacted Ronco and sent them the drawing. They were able to make a poly tank.
Tank removal was a real PITA. I had to remove the vberth decking which involved cutting the tabbing along the hull, After the decking was loose, I had to cut the deck in half to get it out of the vberth. The old tank just barely fit through the vberth door. I had to remove the aluminum trim on the archway from the salon into the vanity area before the tank would pass through. I had to build and fiberglass in a new tank support platform as the old one was water damaged. With the new tank installed and plumbed, I used the old deck as a pattern and cut a new deck from marine plywood. To install the required tabbing, I had to peel up the carpeting on the hull, prep the hull and and epoxy in the roving tabs along each side of the vberth.
Good luck.
