Water Tank Replacement or Removal
Jun 30, 2023
11
hunter 37 Cherubini 3 mile harbor
Aloha
Has anyone removed and replaced their Water Tanks ?
any suggestions or recommendations on this topic ?
Cheers
Dec 28, 2015
1,923
my aluminum tank started leaking around the outlet. I cut a large access port on its top. I took my wire wheel an cleaned up the seams around the outlet, cleaned everything with acetone and ran 5200 down all the seams. We consider the water system not potable and the fix has lasted 5 years. When it finally fails I'll be doing the bladder swap like the one in the previous post.
Likes: SnowSurfer
