water tank odor H-31
381
Hunter 31 1987 Fly Creek Marina Fairhope,AL.
when filling the water tank before a trip, the water tank seemed to never flush out. We have the same dreadfull odor and taste that lots of us have at one time or another.
THe boat i bought sat idle for a long long time so i planned on using small clorine water treatment tablets to try and shock the tank.
any other suggestions?
Chuck
Dec 2, 1999
15,184
Chuck:
Just follow Peggie's process for "shocking" the entire water system. You need to treat it for 8-24 hrs and then flush it.
You may want to consider replacing the lines from the tank too. We never had any problem with our tank, but we always used the water within a couple of weeks after filling it.
Dec 2, 1997
8,961
- - LIttle Rock
Recommissioning the system should solve the problem, Chuck
Do a search for "fresh water maintenance" or "recommission fresh water" to find directions I've posted a zillion times.
Fresh water systems should be recommissioned annually, as a regular part of spring recommissioning. When done according to directions, your water should taste and smell at least as good as what comes out of faucets on land. If that doesn't suit you, install faucet filters. Recommissioning also gets rid of the taste/smell of antifreeze.
Nov 26, 2006
381
Peggy,
You were right on track. works like a champ.
I am ordering your book today.
chuck
Feb 22, 2004
222
Hunter H340 Michigan City
Peggy's Book
Chuck
I have Peggy's book and reference it many times, a great book to have. I also have an H31-84. Every spring I use the method in the book to re-commission my water system. Do replace all your tank lines if they have not been done. Fresh water fill inlet, Outlet, and vent hose. The vent is hard to get to. I also had to re-seal my outlet hose so I took the top of the tank off and "scrubbed" the inside of the tank. That got some build up off the side and bottom of the tank.
Keith
