I have just discovered a leak in the top seal around the water tank on my 84 H31. Looks like caulk around the entire deck plate with numerous hold down screws.
Having never delved into this part of the boat, can anyone with similar model tell me what is under the fiberglass covering? Is this simply a fiberglass box with nozzles for water distribution and vent lines? or is there a bladder in there? also once i remove the many screws holding down the top plate, what is the best/recommended sealant to use?
as always all responses are greatly appreciated. thanks,
Jerry
Jerry
