Tank Help
Jim, I had the same problem in my '84 H-22. my tank is located under and behind the sink. (behind my battery as well) The lower (outlet) fitting on my boat had been broken off before I bought the boat. (Second Wind) Because the tank is built in (wood and fiberglass), and had no interior access, I bought a waterproof access plate and installed it close to the top of the tank, but low enough to enable me to reach the inside of the offending fitting. I did my repair after having cut the hole but before insalling the access plate. I used marine sealant on the flange and nothing on the threads. It sealed great and I can carry a full tank of water without leaks. While I was in there I cleaned the inside of the tank - an added bonus.Let me know if this helped adamsfamilyjr.1@netzero.netgood luck,Jim A
